Nissan Forums | Infiniti Forums NICOclub staff, History and Advertising eMail NICOclub Webmaster Advertising on NICOclub NICOclub main online forums
 How to make a MonZtr
evildky
Classic Z Moderator
71 240ZT, 87 300ZXN/A-T, 91 300ZXTT
Louisville KY
1-31-2004
so I kinda borrowed the title form Rob Zombie, anyhow my car is about to get a complete rebuild soI figured I'd share
starting at the beginning, I picked up the car in St Louis back in 2003 (I paid $1000 for it in it's non running condition, stuck carbs and clogged rusted fuel tank were the major issues)
I ran it in the GRM $2003 challange 1 month after draging it home
I returned that car to the challange a few more times finnishing 10th overall in $2005, the car continues to evolve to get to where it is today
a quick list of mods:
L28ET
T3O4E 57 trim
Megasquirt N Spark http://www.diyautotune.com/cat....html
MSD Blaster 2 Coil
Nissan Motorsport plug wires
455 cc DSM injectors
Pallnet O ring fuel rail http://www.freewebs.com/pallnet/
Aeromotive RR FPR
Treadstone vertical flow intercoolerhttp://www.treadstoneperforman...ooler
Tial BOV
Metal HG
ARP headstuds
Nissan Motorsports Euro Damper
17x11 front and 17x12 rear CCW wheels http://www.ccwheel.com/files/w...assic
sectioned 280Z strut housings http://forums.nicoclub.com/zerothread?id=237090
GC Coil overs 440 lb/in front, 350 lb/in rearhttp://www.ground-control-stor...CA=27
Tokiko Illumina inserts intended for an MR2, BZ3099 front and BZ3015 rear
MSA swap bars front and rear
Techno Toy Tuning camber plateshttp://technotoytuning.com/productdetail.php?p=648
Techno Toy Tuning TC rodshttp://technotoytuning.com/productdetail.php?p=668
Nissan Motorsport Quicksteer knuckles
JSK Willwood adapters http://www.jskinnovations.com/datsun.htm
Willwood superlite 4 pistons front and rear
12.18 vented rotors front and rear
Sumped stock fuel tank
MSD fuel pump
Z specialties1 wire alternator http://www.datsunstore.com/pro...28564
odyssey 680 13 lb battery located behind the passanger seat
Corbeau GTS2 seats
Peak 5 point harnesses
Grant 14" Steering wheeland adapter
280ZX Trubo T5 trans
custom driveshaft form Republic Diesel
Competition Clutches Stage 4 clutchhttp://www.competitionclutch.c...=3272
Fidanza Flywheel http://www.ultrarev.com
88 Z31 Turbo 3.7:1 CLSD
Z31 Turbo CV chafts (flipped the tuip)
Modern Motorsports biltit cv shaft adapter companion flanges http://www.modern-motorsports....id=46
B&M short throw shifter
Ron Tyler Diff Mount
scirocco style dual electric fan
so I rebuilt my engine nd decided to tackle some rust repair while the engien was out, the swap bar mounts were in really bad shape
I rebuilt them using stiffer bracing and moved the moutning nuts further apart to accomodate my larger bar wthout the need of adapter plates
unfortunatley the more rust I fixed the more I found, and after some soul searching i decided it was time to take the chassis bare and rebuild it for the ground up, I'll be updating this thread as I go so keep an eye on it, step 1 is to stript he chassis bare and put it on a rotisserie, I'll update with pic's once thats done, then it's off to the blaster
"if I had all the money I ever spent on cars........I'd spend it all on cars"
S30: "The Rusty Mistress" stripped bare and getting rebuilt from the ground up,
Z31: 315 whp 416 lbft, placed 7th at the GRM $2009 challenge
Z32:sold
S130Z
1983 Datsun 280ZX-T 96' Infiniti G20
Ubon Ratchathani
2-16-2009
 « Re: How to make a MonZtr (evildky)
Wow I envy you all i can afford is a couple of oem replacement parts here and there...i need a new job bad lol
evildky
Classic Z Moderator
Louisville KY
1-31-2004
keep in mind this project has been 6 years in the making.....so far...... and that all of the labor was done my me, myself and I, everything thats wrong is my fault
ans some of the mods were eolutionary, the brakes for instance, I started by swapping to 77-78 readrdrums fomr a parts car taht I bought for $100 and sold more parts than that so I came out money ahead, then swapped to zx read disks using ebay bracksts and parts car parts again, and sold off more than the cost of the car again and later traded them off for a set of race tires, I then found a used set of outlaw vented front disks, sold them for a bit mroe than I paid, then I finally spent the bux on the willwoods, but I bought the hats and btackets months before buying the rest fo the parts so i wasn't out all the money at once and the JSK version is about $100 cheaper thant he AZC version, so I'm finally to the point of building what I want but most of the heavy expense has already been spent
I will however be paying to have the car blasted, but I'll be doing my own paint and bodywork (which is scary because I'm not very goot at it)
Z32:sold
gmac708
1970 - 240Z
Columbus OH
7-31-2008
 « Re: (evildky)
I guess if I had all the money you spent on cars I would spend it on cars too.
Wow. That should be a sweet drive. Are you happy with the way it handles? Of all the mods you did, what was the best value?
Gord
ps. more pictures please
my 240Z http://zclub.nicoclub.com/zerothread/403961
Cam's 240SX http://forums.nicoclub.com/zerothread?id=363388
evildky
Classic Z Moderator
Louisville KY
1-31-2004
the car handles great, I started with 440lb springs all around, and straight line traction was simply non existant, the reduced rear rate really helped
best value overall, was buying a wrecked 280ZX Turbo for $450, that one swap netted nearly a 100 whp gain, and I sold parts off that zero's otu the cost of the donor
Z32:sold
NSR_s30
Drive to live, live to drive
'99 Ford F250 7.3L Diesel, '71 Datsun 240Z
Somewhere in OH
10-8-2004
 « Re: (evildky)
You're definitely a inspiration man for my s30. I'm looking to pick up a L28ET and run a crazy setup like yours. I know whose brain to pick with all the questions I'll have.
- Josh -
BUY MY MATCO PRO SCAN PLUS OBD1-2 SCANNER
http://forums.nicoclub.com/zer...us-oh
prtrillaboss
east coast
4-23-2009
Nice car keep up good work
mikeith
73 240z
lubbock tx
3-21-2009
 « Re: (prtrillaboss)
if i section my struts do i need to replace my illumina's? just noticed that you said you used MR2 ones. and someone said if i sectioned mine i would be riding on bumpstops
evildky
Classic Z Moderator
Louisville KY
1-31-2004
if you have spacers under your catriges you can section them, if not then sectioning them would make your inserts too long
Z32:sold
mikeith
73 240z
lubbock tx
3-21-2009
 « Re: (evildky)
cool i'll check when it comes time to tear the car down. do you have the part numbers to the MR2 inserts you used?
evildky
Classic Z Moderator
Louisville KY
1-31-2004
I updated the list and added the part numbers, I got mine fomr CG when I ordered the coil overs, they will add the correct gland nut at no extra cost, the ones that come with those inserts will not fit the S30 strut housings
Z32:sold
imjdoggie
Datsun 280
reading pa
4-12-2009
 « Re: (evildky)
evil what kind of wheels are you running in the last pic I love them, that is exactly the look I want. Man you look like you are having alot of fun I'm jealous...................
Rare_f8
Remains of a 1990 Z32
Rapid City, SD
10-7-2007
 « Re: (NSR_s30)
Quote, originally posted by NSR_s30 »
Seconded.
All Work, No Play, Make Rare Dull Boy
Don't Miss out! Sign Up Now!
evildky
Classic Z Moderator
Louisville KY
1-31-2004
 « Re: (imjdoggie)
Quote, originally posted by imjdoggie »
Quote, originally posted by evildky »
Z32:sold
kelloggman
73 240z
santa clara ca
4-19-2009
 « Re: (evildky)
where did you get your injectors at and how much
evildky
Classic Z Moderator
Louisville KY
1-31-2004
right now I'm running DSM blue top injectors whihc are 450cc, I got them fomr local sellers at around $10 each, had to buy 2 full sets of 4, and have since bought a third set of 4
Z32:sold
streeteg
hamilton nj
3-31-2007
 « Re: (evildky)
Thanks for the link for the strut sectioning--- I will be needing that very soon....I just have to work on the courage to chop that piece up. I didnt realize what it actually meant--- I thought it was something on the actual coilover, not on the stock piece that houses the strut.
CEO
03 G35C s/c, 93 S13 Vert KA-T, 09 Cube, 72 240Z RB25, 63 NL320, 67 WRL411, 67.5 SPL311, 68 510
Phx, AZ
4-29-2002
Dave, awesome info.
I don't think people realize just how much you know about the S30.
I'm compiling a list of questions about mine, in fact as I get further into the restoration / modification.
TEAM NICO: 146,000 Nissan enthusiasts strong.
REGISTER NOW!!!!
NICOclub on Facebook
evildky
Classic Z Moderator
Louisville KY
1-31-2004
 « Re: (streeteg)
Quote, originally posted by streeteg »
measure twice, cut once!
just take your time and make sure your cuts and welds are in the right place, and hey, you can always cut and weld more until it's right most peoplemake their cut at or near the perch, I make mine higher so if my alignment is off or the weld too deep I can get to it with a die grinder
I didn't have to address mine but a bud has a set someone else welded and they are a little crooked and the strut is absolutely jammed in
and thanks for the kind wrods greg, most fo the things I've learned about these cars left a scar
Z32:sold
kelloggman
73 240z
santa clara ca
4-19-2009
 « Re: (evildky)
i wish i could find them for that cheap
i would to see some pics of the engine bay
evildky
Classic Z Moderator
Louisville KY
1-31-2004
I added a couple of pic's from when I repiped my intercooler
the dsm injectors are bountiful in junkyards or find your local dsm guy's and when they upgrade, get their old ones
Z32:sold
SATAN
1985 300zx heavily modded - 1984 Anniversary 300zx stock - 1990 Q45 stock
Denver CO
1-5-2008
 « Re: (evildky)
Your car looks fun. I like it.
I was debating on picking up an L28ET block and head to start building intake and exhaust manifolds for that engine, but didn't know what kind of interest it would get...
Sharks with fricken LAZER'S
My second quickest 1/4 mile time 11.666 LOL => http://s77.photobucket.com/alb...2.flv
blackice280zx
280zx 1981 x2 1999 volvo v70
louisville ky
5-23-2009
 « Re: (SATAN)
yes dave that car is a monster I need to swing thru and see wut your next mess is lol
evildky
Classic Z Moderator
Louisville KY
1-31-2004
 « Re: (SATAN)
Quote, originally posted by SATAN »
lonewilf sells fabbed intakes for $700, nice piece but I think they priced themselves out of the market for most people, turbo tubular headrs are a very sought after item for the L6, it's unusual to see them for under at all and then they are $800 or better, if you can undercut the market rices then I'm sure they'd sell, the problem is us S30 guys are spoiled with cheap parts so we're cheap
Z32:sold
Perrenial Badass
1973 240Z
Lake Alfred Florida
6-4-2008
 « Re: (evildky)
Uh... he caters mainly to the Z31 community.
evildky
Classic Z Moderator
Louisville KY
1-31-2004
...yeah...and he said he considdered getting an L28ET to fab parts for, and that would apply to....the S30 and S130 community
Z32:sold
blackice280zx
louisville ky
5-23-2009
 « Re: (blackice280zx)
depending on prices I would buy some
SATAN
Denver CO
1-5-2008
 « Re: (evildky)
Yeah, that is the problem. Building intakes/exhaust manifolds for a certain crowd can be difficult. I sell the stuff I do for Z31's and some people think it is priced really high, but then others tell me that if I were smart, I would raise my prices. It seems as though I found a good middle ground for that crowd though.
As for the S30 and 130's I could see it being difficult to compete since they have been around for a while and prices are stupid low on parts. I don't think I would be building regular tubular headers though, cause those are easy to get cheap. I would be building like log style turbo relocation manifolds and stainless tubular manifolds to relocate the turbo. It's a lot easier for the inline 6 rather than the v6 for obvious reasons.
Either way, just an idea I was throwing around. Got any suggestions as to where to gauge interest? I would post here and on Hybrid Z, but other than that, I don't know many s30/130 sites.
SATAN
Denver CO
1-5-2008
 « Re: (SATAN)
Just looked at the Lone Wolf intakes. That is a really good deal for a manifold and a fuel rail! Does anyone know if that $700 price comes with the powder coating they show? Also does anyone have any pictures of the inside of the plenum? Do they do velocity stacks of any kind?
Perrenial Badass
1973 240Z
Lake Alfred Florida
6-4-2008
 « Re: (evildky)
I was referring to the "cheap" part... it's odd, in quotes, stuff you bold doesn't show up. Figured you would know us Z31 guys are cheap bastards.
evildky
Classic Z Moderator
Louisville KY
1-31-2004
ah, a little sarcasm, sorry I missed it
and when I said turbo tubular header I of course meant turbo exhaust manifold, and one that moves the turbo forward would be nice
Z32:sold
NicUzumaki
240sx 82dodge Rampage[rebuilding]
surrey bc
10-13-2009
 « Re: (evildky)
dont worry about the body work,
only think is is that the type of bondo mattersk
zyklon or what ever, its blue
works amazing
I don't like your tone, you better watch your self or
I'll stab you in the eye with a soldering iron.
evildky
Classic Z Moderator
Louisville KY
1-31-2004
gotta correct al my links now
Z32:sold
kelloggman
73 240z
santa clara ca
4-19-2009
 « Re: (evildky)
so whats the cars condition now
evildky
Classic Z Moderator
Louisville KY
1-31-2004
running like a champ, I might be autocrossing it tomorrow weather dependant, my fuel issues were actually an over rich condition, I did a bit more datalogging and tuning and found I was only building 10 psi (keep in mind this is 10 psi form a 53 lb/min turbo and on an n/a engine) some additional tuning got me up to around 13psi I really need to get ti on a chassis dyno and get the spark curves refined
Z32:sold
» Return to Classic Z General
Nissan 350z Articles and Information   nissan 370z Articles and Information
    -  NICO Main Forums
    -  NICOclub Homepage
    -  370zclub Homepage
    -  350Zclub Homepage
    -  Z32club Homepage
    -  Classifieds
    -  Advertisers Marketplace
    -  Fabricators Marketplace
Car Finance Advice Nissan Infiniti News Archive
240sx technical information Nissan technical information
Infiniti technical information Nissan Infiniti Car Owners Homepage
 Car Specific Links
-  Z-Series Forums
-  Cube
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  QR
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
